1995 Saturn SW1 Idle too high
1995 SATURN SW1
196 MILES • 4 CYL • 2WD • MANUAL
MARCYW
I have a 95 Saturn SS1 Wagon with 195,000 on it and have kept it to a tee!
All of a sudden it is idling high especially when I clutch to put the brake on. Goes to 2,000- 3,000 rpms and when it sits at just normal idle, it idles at 1-1/2...just too high.
Any ideas? Thanks.
Marcy Wood
Jan 28, 2010 at 9:36 PM
MMPRINCE4000
  • 8,548 POSTS
If idle is normally 800-900 rpm and it is idleing at say 1200, it would be a malfunction in the IAC (idle air control valve) or circuit.
But an idle of 3,000rpm is either a vacuum leak or possibly a binding throttle plate.
Was there an abnormal event that caused this, like a backfire or something?
Jan 28, 2010 at 9:48 PM
MARCYW
There was not a backfire but it did start to happen after a possible overfill of oil. Not a drastic overfill, just a bit. Thanks Marcy
Jan 28, 2010 at 11:35 PM
