1994 Saturn SW1 car overheating
212,000 MILES • 4 CYL • FWD • MANUAL
TPAL315
We own a 94 saturn with 212000 miles that keeps overheating...we've changed the water pump the thermostat and the radiator is less then a year old. we flushed the system and the hoses didnt seem to be blocked and we have no leaks. we dont get alot of pressure in the outgoing hose...could it be the radiator is the problem ???
May 18, 2009 at 7:30 AM
  • 75,988 POSTS
Double check the radiator if its clogged-up if not could be airlock in the system try bleeding it-if it continues get it block and pressure tested.
May 18, 2009 at 8:38 AM
