Heater problem
2001 Saturn Station Wagon 6 cyl Front Wheel Drive Automatic
Can you advise measurement for Saturn Heater core O rings. Have a fluid leak from the O rings but good old GM won't sell O ring kit. They want Core replacement for 500 dollars. all for 3 bucks worth of O rings. It is o rings for sure as I pulled the connections and put some Teflon tape over the rings. --Leak stopped. If I just knew ring size I could spend 5 bucks and have problem solved. Needless to say this is the last GM car for me.
Feb 21, 2010 at 8:11 AM
