1996 Saturn Station Wagon
1996 SATURN STATION WAGON
SUSANSCAR
1996 Saturn Station Wagon 4 cyl Front Wheel Drive Manual
I have replaced the slave cylinder and the master cylinder for the clutch. I bled the system according to the instructions. There is no clutch response now. Do you have any suggestions? Thank you Susan
Feb 1, 2009 at 11:38 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6d2bd0886d="susanscar"]1996 Saturn Station Wagon 4 cyl Front Wheel Drive Manual
I have replaced the slave cylinder and the master cylinder for the clutch. I bled the system according to the instructions. There is no clutch response now. Do you have any suggestions? Thank you Susan[/quote:6d2bd0886d]
What was the initial problem and reason for changing the Clutch Slave and Master Cylinder.
Have you checked the Clutch Pedal Ajustment?
Feb 1, 2009 at 11:48 AM
SUSANSCAR
My car was hard to get in gear and shift. There wasn't a problem with the clutch slipping, so I figured it must have been either the master or slave cylinder was bad. Both were changed to be sure. Could it be possible it would have to be power bled? Is there a special tool needed to do this? Thank you Susan
Feb 2, 2009 at 2:12 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:1788abe2b8="susanscar"]My car was hard to get in gear and shift. There wasn't a problem with the clutch slipping, so I figured it must have been either the master or slave cylinder was bad. Both were changed to be sure. Could it be possible it would have to be power bled? Is there a special tool needed to do this? Thank you Susan[/quote:1788abe2b8]
Try this first....
Remove the Cap from the clutch master cylinder, make sure it is full. Then loosen the bleeder on the slave watch to see if it will gavity bleed on its own. If so let it almost empty the master and fill it again do this twice, then tighten bleeder screw, make sure master is full and put cap back on. test clutch...
Feb 2, 2009 at 7:21 AM
SUSANSCAR
Thank you for your help and quick responses. I figured out the problem. There is no bleeder valve on the slave or master cylinder. I purchased a whole new clutch and slave, master cylinder from the saturn dealer. It had to be a sealed unit, unlike the one I purchased at the auto parts store. If anyone ever inquires about this problem it is best to not try and save money as it wound up costing me more in the long run and certain makes of cars like the saturn only respond to the exact product. Thank you again for your input. Susan
Feb 2, 2009 at 1:14 PM
