1996 Saturn Sport Coupe electric fan
1996 SATURN SPORT COUPE
110,000 MILES • 4 CYL • FWD • MANUAL
MANNYSAYULA
electric fan is not engaging, checked fuses and relay and are ok. Also checked fan motor and also worked with direct votage. Is there a sending unit that turns on the fan, that is in the engines coolant?
Jul 25, 2009 at 9:15 AM
SATURNTECH9
  • 30,869 POSTS
there is a coolant temp sensor screwed into the head below the lower radiator hose if ur going to change that then make sure u check the connector to make sure its not all corroded some of the sensor leaked into the connectors corroding them if it is change the connector too.let me know what u find.
louie
Oct 5, 2009 at 6:18 AM
