Hello
Thanks for the donation.
Check drive belts for signs of damage/loose fits. Also need to inspect battery cables and terminals. Ensure cables are tightened properly at both the battery as well as the starter and frame. Make sure terminals are free of any corrosion. If all is OK here, need to have starter tested. Most part stores do this for free. They will also test alternator and battery for free as well, on or off of vehicle.
Post results of tests and I will follow up.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Saturday, February 7th, 2009 AT 11:55 PM
