1994 Saturn Sport Coupe Replacing high side hose
1994 SATURN SPORT COUPE
200,000 MILES • 4 CYL • FWD • AUTOMATIC
JOJO2799
I've been trying to recharge the ac system. Whats happened is I went to charge it up and the low side hose started to leak? So I replaced the low side hose then went to recharge again and the High side hose started to leak? Now I am getting ready to replace the high side hose and starting to wondering if there is to much pressure in the ac system and causing the hoses to puncture. So should I let the pressure out and how would I do that before recharging with the kit they gave me.
Thanks, Johnny
Jun 28, 2010 at 10:33 AM
MERLIN2021
  • 17,250 POSTS
Best bet is if you are having this much trouble, take it to a qualified A/C shop, by Federal law, the system needs to be vacuumed out and freon captured to a tank. This will also tell you if there are any leaks. Recharging with the charging station is the BEST way to fill the system. You cant get a proper charge into the system with the hand held gauges.
Jun 28, 2010 at 10:46 AM
