1991 Saturn Sport Coupe starter
1991 SATURN SPORT COUPE
BENGENIE
Engine Performance problem
1991 Saturn Sport Coupe 4 cyl Front Wheel Drive Automatic
hello, my daughters saturn was inconsistantly starting. i replaced the spark plugs, which had one chamber drenched in oil. checked fluids, etc.. when i start it, the starter spins but no turnover. it may or may not take a couple of times but then it starts right up. where should i look next?
Feb 23, 2010 at 12:58 AM
SATURNTECH9
  • 30,869 POSTS
[quote:db057ea409="bengenie"]Engine Performance problem
hello, my daughters saturn was inconsistantly starting. i replaced the spark plugs, which had one chamber drenched in oil. checked fluids, etc.. when i start it, the starter spins but no turnover. it may or may not take a couple of times but then it starts right up. where should i look next?[/quote:db057ea409]
as far as the oil in the plug wires u need to replace the valve cover gasket it's leaking into the plugs and wires.now to ur starting concern if u can hear ur starter spining really good but it's not turning the engine over then what's happening is ur starter bendix isn't pushing the starter gear out.u need a new starter.if u pull the starter out u can make sure that's what it is by taking it to a auto parts store like autozone u can't test it in the car then u can see the gear not kicking out.let me know what u find.
Feb 23, 2010 at 5:15 AM
