2003 Saturn SL2 brake light stays on
MADONE1006
Brakes problem
2003 Saturn SL2 Front Wheel Drive Automatic 178000 miles
my saturn sl2 brake light comes on after a couple seconds of driving and goes off when i stop . also when i go to stop i have to press the brake pedal further and takes car longer to stop, brakes are only four or five month old.
brake fluid full and a mecanic said brake pads are fine but i am getting rececked. please help. also breaks were hesitating making th cajerk back and fourth alittle
Mar 20, 2010 at 2:47 AM
SATURNTECH9
  • 30,869 POSTS
[quote:6e5db133ab="madone1006"]Brakes problem
brake fluid full and a mecanic said brake pads are fine but i am getting rececked. please help. also breaks were hesitating making th cajerk back and fourth alittle[/quote:6e5db133ab]
as far as the light goes unplug the connector from the master cyclinder jump the the two wires across cycle the key see if the light goes out If it does then u have a bad switch If The master cylinder Is full.if the car is jerking in the front ur rotors are warped.if u pull up on ebrake arm while driving without locking the arm if u feel the jerking then it's ur drums warped.as far as ur low pedal adjust ur rear brakes let me know what u find.
Mar 20, 2010 at 3:09 AM
