2002 Saturn SL2 Won't turn over, stalls at idle
2002 SATURN SL2
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
LCAMPBELL420
When I start it it cranks & chokes, now wont crank at all. I've been having this problem for 2 years. It stalls at stop lights as well unless you keep your foot on the gas in neutral. All the lights go on when you turn the key, so it can't be the battery(which has also been replaced). I've had the fuel injection cleaned & the spark plugs changed with no change.
Jul 14, 2010 at 1:45 AM
SATURNTECH9
  • 30,869 POSTS
So you have a crank no start?The starter isn't spinning the engine?Or the engine crank's over and just won't start?Your description is a little confusing.Do you have a multimeter?
Jul 14, 2010 at 4:09 AM
