2002 Saturn SL2 Won't start.
142,000 MILES • 4 CYL • 2WD • MANUAL
08DRAGONS
I left my lights on one day and my battery died. So I tried to jump it off and it didn't work. I then went and bought a new battery. It still didn't work. I decided to check the fuses because the radio wouldn't come on. I changed all of them and sure enough the radio came on, but it still wouldn't start. I changed the fuel pump relay, and it still wouldn't start. I checked the spark plug, it was good. I made sure I had gas in it, still nothing. I don't know what to do. What could it be? Please help!
Jun 7, 2010 at 5:09 PM
  • 75,988 POSTS
Hi 08dragons, Welcome to 2carpros and TY for the donation
Do below to determine if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 7, 2010 at 6:43 PM
