2002 Saturn SL2 Won't start.
08DRAGONS
  • 2002 SATURN SL2
  • 4 CYL
  • MANUAL
  • 142,000 MILES
I left my lights on one day and my battery died. So I tried to jump it off and it didn't work. I then went and bought a new battery. It still didn't work. I decided to check the fuses because the radio wouldn't come on. I changed all of them and sure enough the radio came on, but it still wouldn't start. I changed the fuel pump relay, and it still wouldn't start. I checked the spark plug, it was good. I made sure I had gas in it, still nothing. I don't know what to do. What could it be? Please help!
Tuesday, June 8th, 2010 AT 12:09 AM
Hi 08dragons, Welcome to 2carpros and TY for the donation
Do below to determine if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, June 8th, 2010 AT 1:43 AM
