Trunk wont close
2002 SATURN SL2
MICGOSC
Hello, I'd like to know how much it would cost to repair my trunk. It will not close anymore, & I currently have it tied down tightly. I did notice the plastic/rubber piece inside the lock is torn, so would this be all that needs to be replaced or the whole lock itself, & like I said asked earlier, how much would it cost? Thanks for your help!!
Oct 3, 2009 at 2:46 AM
SATURNTECH9
  • 30,869 POSTS
u could have a bad latch but since u said the plastic cover is damaged ur latch is ethier bent in towards the trunk or ur striker is out of adjustment those are the two most comon causes.what i would do is look at the striker and look where the two 10mm bolts hold it on and see if u can see where there are marks of where the bolts used to be if u cant the adjustment is probably fine.next remove that plastic cover on the latch fold both back seats down shine ur light into the trunk have someone close the trunk holding it down see if the latch is too far foward to latch if it is u can put the plastic cover back on and grab the latch and bend it towards u so it will be aligned.try those wo things first.let me know what u find.
louie
Oct 3, 2009 at 4:33 AM
MICGOSC
Hi, thanks for the quick reply!! There is an actual rubber piece on the underside of the trunk lid that is dangling & can easily be torn off completely, which I have not torn off completely yet. I wasn't sure if I should? Also, there is a metal thing inside that does turn & click, so I think that's what you mean when you say the adjustment is working fine, so I do think that part is working. It's just that rubber thing is worn & I wouldn't be able to fix it myself, so what would you think a repair like this would cost? Thanks again!!
Oct 3, 2009 at 5:26 AM
SATURNTECH9
  • 30,869 POSTS
as far as the striker adjustment i was talking about by checking the marks where it might have sliped out of place is at the bottom of the opening down by ur bumper.also the cover i was talking about is on ur latch on ur trunk lid u said it latchs and clicks so it sounds like thats working if it opens and closes.i told u to take off the cover off that thing that latchs and clicks and have some one hold the trunk closed to see if ur trunk lid where the latch mounts is just bent and needs to be bent back its not hard to bend back if u have a little strength i have done it many times.i was trying to save u money.if it was the latch or it was bent it would cost like an hr labor so depending on the labor rate 100 plus latch then depending on the latch if it was power or not 40-80 for the latch maybe.
Oct 3, 2009 at 6:06 AM
MICHAELTRASK
You guys are great I'eve had that trunk problem since July of this year when I bought the car and it cost me $50 for that and my head lights to be fixed I'eve also had trouble with the tranny had it replaced twice so far lol but the minute I read about what you recamened it worked out great except I had to close it from inside the trunk to get it to work correctly is it cheaper to go to the scrap yard to get a a latch catch then having to nbuy a new one
Dec 14, 2013 at 4:16 AM
