[quote:299781543d="cgalinski"]Well, since I was a BIG chicken and did not want my car sabataged (I am sure he wouldn't have, but ya neva know) I called him back and had a woman to man converse w/him. Ok, this is what he said, my service engine soon light is not going to go off, because of this.
I had 4 things wrong w/the diagnostics, these are the codes:
1. P0128 coolant thermastat, just to let ya know, my car does not overheat at all, knock on wood.
2. P0442 evap system....he says it is a bad gas cap...my Saturn book states that usually one replacing the gas cap will make the light go out, I mean taking the gas cap off and putting it back on again, not getting another one.
3. P0731 The valve body thing.
4. U100....he said it looks like I have had a battery replacement or something, I told him I did a while ago.
But he said, I won't break down or anything if I don't get the gas cap fixed or the other things....NOW, the ONLY thing that is now concerning me is.....I have inspection due in July, will they allow a passing inspection w/that stupid light on?
By the way, I will give a donation to this site when I have built up my savings again.[/quote:299781543d]
so ur inspection in july is it a state inspection or a emissions inspection?ur code p0128 is ethier the thermostate bad staying open and always letting ur coolant circulate.or u have a bad coolant temp sensor miss reading ur thermostate being bad.ur p0442 could have been ur gas cap wasnt tight and the code is set in history or u could have a bad gas cap when u get ur car back look at ur gas cap seal see if its cracking if it is u will have to replace ur cap.or u could have a vapor leak some where in ur fuel system or a bad fuel pressure sensor or wiring to it.it could be alot of things on that.hopefully ur p0731 will be gone with this transmission repair.ur u1000 is usually a computer communication error.sometimes it just sets as a freak thing play that one by ear.as far as ur donation if u want to make a donation thats fine when ever ur ready.thanks for the donation in advance glad ur enjoying are website.let me know when u know how ur car turns out and if ur up for a state inspection or a emissions inspection.
Apr 8, 2010 at 12:37 PM
