2002 Saturn SL2 Odometer
180,360 MILES • 4 CYL • FWD • AUTOMATIC
PIATAR
  • 5 POSTS
Odometer does not light up. Is there a cheap fix?
Nov 9, 2010 at 10:51 PM
KHLOW2008
  • 41,812 POSTS
Hi PIATAR,
Thank you for the donation.
Either the digital dispplay is bad or has a loose connection.
If the unit is bad, it has to be replaced. If it is a loose connection, removing the cluster to check and tighten migh work.
Unless you DIY, if not it is not going to be cheap as removal of the cluster alone is a 1.3 hour job.
Nov 10, 2010 at 1:18 AM
SATURNTECH9
  • 30,869 POSTS
Not meaning to but in but most likely you need a new odometer bulb every one i have had like that has just been a bad bulb.So if you do end up pulling the cluster yourself make you get a odometer bulb before you remove the cluster.
Nov 10, 2010 at 3:37 AM
