2002 Saturn SL2 lock-unlock switch on driver door of 2002 s
102,538 MILES • 4 CYL • FWD • AUTOMATIC
WHRIONTE
  • 5 POSTS
My 2002 Saturn SL2 driver door lock (the lock-unlock switch) is broken. I would like to know how to remove it in order to be able to lock the doors from the inside. I have its replacement but no idea how to replace it on my own.
Nov 10, 2010 at 10:33 PM
SATURNTECH9
  • 30,869 POSTS
Look at the door lock switch you should see a little cut out at the edge of the switch that is where you insert a small pocket screwdriver to release the switch then pull the switch towards you.
Nov 11, 2010 at 3:07 AM
