BCM?
51,000 MILES • 4 CYL • FWD • AUTOMATIC
TILDENG
Where is chime module for headlights on or ignition on with door open ?
Oct 4, 2010 at 6:40 AM
SATURNTECH9
  • 30,869 POSTS
Your car use's the body control module instead of a chime module for all the function's that the chime module would do.I posted a wire diagram for you and also emailed it to you.
https://images.2carpros.com/forum/automotive_pictures/416332_2002_SL2_warning_system_wire_diagram_1.jpg
Oct 4, 2010 at 6:57 AM
TILDENG
Got your answer, have a Mac, can't print out tiny diagram. Still don't know where this module is physically located.
Oct 4, 2010 at 7:54 AM
SATURNTECH9
  • 30,869 POSTS
The body control module is under the dash top which is the top of your dash.
Oct 4, 2010 at 8:32 AM
