2002 Saturn SL2 Clanging Noise For Less Then a Second After
2002 SATURN SL2
51,000 MILES • 4 CYL • FWD • AUTOMATIC
TAGOULD_OU
My 2002 SL2 starts everytime with no problems. However recently, immediately after it starts there is a clanging sound that lasts less then a second. It sounds like the noise is coming from the area where the starter is. And it doensn't make the sound with every start. I can go 15 starts in a row without hearing it but then it will happen 3 times in a row. What could this be? Thank you.
Oct 12, 2009 at 2:57 PM
  • 110,244 POSTS
Wow! THat could be many things. I would like you to try something and let me know what you find. Take a rubber mallot and tap on the exhaust system. Listen closely near the catylatic converter to see if you hear the sound. I think that maybe the converter may have come loose inside. Also, since the sound seems to come from near the starter, make sure it isn't loose.
Let me know what you find.
Oct 12, 2009 at 3:04 PM
