2001 Saturn SL2 Will not start
89,000 MILES • 4 CYL • FWD • MANUAL
BNEIHART
the engine turns over but does not start. I can hear the fuel pump when I first turn the key. What do I start with.
Oct 17, 2009 at 4:05 AM
  • 75,988 POSTS
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
If both fuel pressure and blue spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Oct 17, 2009 at 4:13 AM
