2001 Saturn SL2 starts then dies
160,000 MILES • 4 CYL • FWD • AUTOMATIC
BENK01
  • 5 POSTS
been workin on car for half a day, started one morning went to start car and wouldnt start, starts then dies. i've replaced fuel pump, filter, 45 psi of fuel at rail, and holding, good spark while cranking, can keep car running by spraying starter fluid down intake. just seems like something is shutting down fuel after 1 sec. Help Please, Ben
Jul 17, 2010 at 1:41 PM
SATURNTECH9
  • 30,869 POSTS
Does your security light stay on or flash when the key is on?Get a noid light and test each injector connector for a injector pulse.my guess is you don't have a injector pulse.Also see if your injector fuse is blown in the under hood fuse box.
Jul 17, 2010 at 3:14 PM
BENK01
  • 5 POSTS
no security light, will check on a noid light, fuel pump will check fuse, Thanks. Ben
Jul 19, 2010 at 2:50 PM
SATURNTECH9
  • 30,869 POSTS
Ok keep me posted also check that injector fuse and let me know what you find.
Jul 19, 2010 at 3:07 PM
BENK01
  • 5 POSTS
saturntech9 picked up a noid tester, while cranking injectors initially get a light (fires) then no light(dies)(still cranking) 3 seconds later I get a light ( fires ) then dies etc, same on all 4 injectors. fuel fuse under hood good, fuel fuse under dash good. (I do get 45psi to the fuel rail). is their a chance it could be crank sensor?
Jul 20, 2010 at 9:56 AM
SATURNTECH9
  • 30,869 POSTS
If you had a bad crank sensor you would have no spark and the car wouldn't start.But you said you have spark and the car starts on starting fluid.It really sound's like your security system is keeping it from starting you said you have 45psi of fuel pressure which is great.But the fuel isn't getting into the engine when the security system activates it shuts off the injector pulse.Which it doesn't sound like your getting much pulse.
Jul 21, 2010 at 6:20 AM
BENK01
  • 5 POSTS
rented a scan tool today, no codes read? put remote starter on valet mode, made no differance?
Jul 21, 2010 at 9:41 AM
SATURNTECH9
  • 30,869 POSTS
If the scanner you rented won't read body control module code's then you wouldn't see the code if you had one the bcm shuts down the injector pulse as part of security.You never said you had remote start before on that car to have remote start you need to install a bypass module because you have a passlock sensor to allow your car to start.check it out.
I'm not sure if they wire the module in to replace the passlock sensor or how they do it but if it failed and they wired it in in place of the passlock sensor then that could be your problem.I would look in to that.
Jul 22, 2010 at 5:52 AM
BENK01
  • 5 POSTS
Thanks, I'll check it out!
Jul 22, 2010 at 8:41 AM
