2001 Saturn SL2 Losing small amount of coolant
88,000 MILES • 4 CYL • FWD • MANUAL
BIGBEE543
Vehicle is losing a very small amount of coolant. Does not overheat and temp gauge is constant between a quarter and a half. Produces real good heat. Nothing noticeable under vehicle but can intermittently smell the coolant after driving. Had vehicle checked by my mechanic and they found a small leak at the intake. Anything to look for when replacing the intake gasket? Also, I just recently spoke with you in regards to a high idle and I am going to replace the coolant temp sensor. Can the coolant temp sensor be affected by the coolant leak at the manifold? Thanks for your time!!
Mar 26, 2010 at 8:17 AM
SATURNTECH9
  • 30,869 POSTS
No there's nothing to really look for when replacing the intake gasket it's pretty common for 2000-2002 dual over head cam models to leak coolant from the gasket just have the gasket replaced and u will be good on that one.as far as ur coolant temp sensor making the gasket no that has nothing to do with that leaking.they just leak I have replaced alot of intake gaskets that leak.leak me know how u make out.
Mar 26, 2010 at 9:14 AM
