Engine idles too high?
120,000 MILES • 4 CYL • FWD • AUTOMATIC
PAUL CALGARY
the car starts fine and runs fine as well, what is happening is the car wants to push itself,it will go along at 30 kms/hr without touching the gas,if you slip it into neutral it revs @ 1800 rpm untill you come to complete stop,then the idle will go back down to @ 850 where it suppost to be, it shows no codes, the trottle body has been cleaned, we also replaced the air idle control as well,seems a little better but still wants to push itself along. my machanic is now sratching his head as well, again no codes come up, help please.
May 4, 2010 at 10:28 AM
SQM
  • 6,383 POSTS
You might want to adjust your idle speed to see if that helps.
https://www.2carpros.com/articles/engine-idles-too-high
Also check for any type of vacuum leak.
I have attached the procedure on how to do that for your reference.
Aug 2, 2021 at 8:09 AM
