2001 Saturn SL2 Engine Temp Light on Display Panel
110,000 MILES • 4 CYL • FWD • AUTOMATIC
IRISH48
Engine temp light goes on in cold weather when I start engine and goes off a few minutes in idle and does not go on again.
Dec 16, 2008 at 3:34 AM
  • 75,988 POSTS
Sir-I've looked for an engine temperaturre gauge sender/switch but none listed for yours-However you might want check the connections on the coolant temperature sensor and also measure its resistances with an ohmmeter-Cold and Hot
https://images.2carpros.com/forum/automotive_pictures/12900_CTS_values_4.jpg
Dec 16, 2008 at 4:47 AM
