2001 Saturn SL2 Car hot, fans on, car acts like it is neutr
91,000 MILES • 4 CYL • FWD • AUTOMATIC
AFLAHERTY
The other day I was driving my Saturn (as usual) fans running, air conditioning on, loss of power (typical) and then all of a sudden my rpm's increased and my car was only on average going 30mph. It was like I had accidentally shifted into neutral.
I made it back to work and in about 45 mins I headed home (estimated 15-20 miles) the car drove fine (no ac on) and by the time I got home the same scenario as above happened. This time, I had to pull over, shut my car off and restart it to make it the rest of the way home.
Currently, my car is waiting to be worked on at a transmission shop. I read previous car questions on your site and it sounds like other people have had this same problem. Something with TPS? Any help would be much appreciated so that I don't waste a ton of money at the transmission repair shop.
Oh, and when I run my ac and am at a stop I have to hold my foot on the brake (hard) so that my car doesn't lurch forward.
Thank you,
A Flaherty
May 26, 2010 at 8:34 AM
SATURNTECH9
  • 30,869 POSTS
Your looking at the L model which is a totally differnt car then you have the s model tps don't go bad often.If you could get me your trouble codes which your car should have with the problems your having I would be more then happy to help you out.Let me know the numbers of the codes.
May 26, 2010 at 9:12 AM
AFLAHERTY
I apologize, I was reading so many of the posts on the forum that I typed the incorrect car type.
My vehicle is a 2001 Saturn L200, not an SL.
I did receive a call from the transmission shop and they did receive the code back on a bad TPS.
The mechanic drove my car around today and it didn't act up at all. I am just thankful it is not the transmission.
To be safe, I am going to install a new TPS and then drive it for a while, then get the transmission fluid changed.
Thank you so much for a quick response.
A Flaherty
May 26, 2010 at 11:03 AM
SATURNTECH9
  • 30,869 POSTS
Glad to hear you got your car hopefully working again.Let me know if that doesn't fix it and you need further help.
May 26, 2010 at 1:33 PM
