2001 Saturn SL2 2001 saturn sl2 crack in engine part
2001 SATURN SL2
20THCENTBOY
  • 19 POSTS
Engine Cooling problem
2001 Saturn SL2 4 cyl
I have a crack in this engine part and don't know what it is called. Need help. Coolant hose hooks to cracked part and coolant overflow I fixed with brake line and quiksteel temporary. Thanks for suggestions.[img:179fa69369]http://www.2carpros.com/forum/automotive_pictures/548414_SANY0005_2.jpg[/img:179fa69369]
[img:179fa69369]http://www.2carpros.com/forum/automotive_pictures/548414_SANY0006_2.jpg[/img:179fa69369]
[img:179fa69369]http://www.2carpros.com/forum/automotive_pictures/548414_SANY0007_1.jpg[/img:179fa69369]
Aug 20, 2010 at 6:46 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.That would be your intake manifold.I would recommend getting a used one the new one's are going to be pricey.
Aug 20, 2010 at 7:03 AM
20THCENTBOY
  • 19 POSTS
Thanks. Now thats what I am being told that it is the intake manifold. Called a junk yard, they sent me a picture of a SOHC manifold but it did not look like the same part at all. Would this be a DOHC part? Vin number had a 7 in the code. We are told that makes it a SOHC. Once I see the exact part I will be fine, but no answers so far that match together.
Aug 20, 2010 at 7:26 AM
SATURNTECH9
  • 30,869 POSTS
Vin 7 is a dohc vin 8 is a sohc you have the dohc the single is totally different it's made out of metal and yours is plastic.Make sure you get a new intake gasket to go with your used intake.A 2000-2002 dohc intake will work on your car.
Aug 20, 2010 at 7:43 AM
20THCENTBOY
  • 19 POSTS
Let you know what happens if i find one. thanks for all the advice.
Aug 20, 2010 at 7:50 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome that's what were here for.Keep me posted.
Aug 20, 2010 at 9:59 AM
AUGIE1981
Hi I have a 2002 Saturn sl2 the pipe on the pic broke also to change it do I have to replace the hole back piece???
Dec 22, 2014 at 10:57 AM
