2000 Saturn SL2 Turn signals/Hazard Lights
107,500 MILES • 4 CYL • FWD • AUTOMATIC
PEARTHEBEAR
I stopped my car in front of my building and put on the 4-ways to go upstairs for a couple minutes. When I returned, the 4-ways weren't on anymore, and my signal lights weren't working either.
Is there a reset switch, or something was pulled loose in the steering column?
May 12, 2010 at 10:45 PM
SATURNTECH9
  • 30,869 POSTS
There is no reset button for them have u checked the fuses?what happens when u put the turn signal on does the indicator on th dash atleast light up?do u have a multimeter?let me know.
May 13, 2010 at 4:57 AM
PEARTHEBEAR
I've checked the fuses before, there are no signal lights showing on the dash, it's all dead. When I push up/down the lever to signal...nothing.
No, I don't have a multimeter.
May 13, 2010 at 9:04 AM
SATURNTECH9
  • 30,869 POSTS
If u want to trouble shoot ur problem u will need a multimeter there pretty cheap and nice to have around the house for problems like this.it could be ur switch or flasher relay without some tests with a multimeter I can't really say what it is.let me know if u want to get a meter and do some tests.
May 13, 2010 at 11:45 AM
