2000 Saturn SL2 Security interlock prevents car form starti
170,000 MILES • 4 CYL • FWD • MANUAL
VANDEMARK
My saturn security system locks out car to start. it is intermentant but getting worse. Some times I can play with locks and keys and afer about 10 mis it will start. one thing i notices is key is worn, had new key made but but not at dealer but same problem. If can disable that would be great.
Jun 28, 2010 at 11:13 PM
SATURNTECH9
  • 30,869 POSTS
[quote:f9861918ea="Vandemark"]Electrical problem
2000 Saturn SL2 4 cyl Front Wheel Drive Manual 170000 miles
My saturn security system locks out car to start. it is intermentant but getting worse. Some times I can play with locks and keys and afer about 10 mis it will start. one thing i notices is key is worn, had new key made but but not at dealer but same problem. If can disable that would be great.[/quote:f9861918ea]
First of all thank you so much for the donation.So when it doesn't start the security light flashes or stay's on?Also when this happens does your horn go off or anything like that?Does your remote open up the car when this happens?Does anything else not work when it start's like gauge's or light's etc?
Jun 29, 2010 at 6:13 AM
VANDEMARK
the alarm does not go off and i can lock and unlock with touch key
Jun 29, 2010 at 10:06 AM
SATURNTECH9
  • 30,869 POSTS
Alright let's start with getting your engine transmission and body control module code's.To get your body control module it take's a more advanced scanner then your average auto part's store one.Make sure the one you use reads body control module code's those code's are going to be the most important ones since it control's your security system.
Jun 29, 2010 at 3:44 PM
