2000 Saturn SL2 po174 lean bk 2 // po171 lean bank 1
2000 SATURN SL2
IFIXGM
Computer problem
2000 Saturn SL2 6 cyl Front Wheel Drive Automatic
We have a satun sl2 year 2000 w/ po171/po174 dtcs.Usually we smoke the intake and check for obvious vac leaks (none that we have found),Then both o2 sensors (pre cat) were replace by another shop.The code po171 went away after the o2 sensors were replaced,however the po174 returns after 3 drive cycles. Any help would be awsome!!! Thanks.
Oct 4, 2009 at 7:26 AM
SATURNTECH9
  • 30,869 POSTS
Is this a 3.0 v6 ls Saturn?first question I need answered.
Louie
Oct 4, 2009 at 6:37 PM
IFIXGM
Yes it is a 3.0 v6 sorry it took so long to get back.
Ray.
Oct 8, 2009 at 12:38 PM
SATURNTECH9
  • 30,869 POSTS
If u have checked for vaccuum leaks then the only thing left is a bad mass airflow sensor I replaced alot of them for that code or both those codes there even was a bulletine on that.I would replace the mass airflow let me know how it comes out.
Louie
Oct 8, 2009 at 12:49 PM
