2000 Saturn SL2 oxgen sensers
2000 SATURN SL2
FERRELLD92
Engine Performance problem
2000 Saturn SL2 4 cyl Front Wheel Drive Automatic
how would the car act if this is the problem and how many are there in this car how to tell which one is bad
Jul 4, 2010 at 2:27 PM
SATURNTECH9
  • 30,869 POSTS
You have two o2 sensor's one in the exhaust manifold and one right before the cat.When they go bad they usually set a code and don't have any symptom's.Why don't you tell me what your car is doing.
Jul 4, 2010 at 2:33 PM
FERRELLD92
I have to give it gas to get it to start . have alot of exost.Today it would not start.
Jul 4, 2010 at 3:04 PM
SATURNTECH9
  • 30,869 POSTS
If you have to give it gas to start i would say you have a bad coolant temp sensor.Pretty common for them to go bad and cause all kind's of symptom's.There only 10 make sure you get a brass tipped one the plastic tipped one's crack.When you change it make sure the engine is cold you will loose coolant.When you change it make sure you inspect the connector going to it if it's corroded then you need to change the connector too.They usually turn green or blue when they do i emailed you a diagram of where the coolant temp sensor is.Give changing that a try and let me know what happens.
Jul 4, 2010 at 4:18 PM
