WHEN I PUT IN KEY TO START KEY WILL NOT TURN AND GEARS WILL NOT GET OUT OF PARK, WHAT IS THE PROBLEM
Jun 30, 2009 at 3:57 AM
SATURNTECH9
✓Experienced Mechanic
So the key won't turn at all?Have you tried turning the steering wheel while turning the key at the same time?Also look at the key does it looked badly worn down?If so do you have another key that isn't so worn down to try?Also have you tried wiggling the key up and down while trying to turn it?
