2000 Saturn SL2 HOW TO REPLACE THE A/C Clutch?
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
XUYENDO1
How to replace the A/C compressor Clutch?. Also where is the fuel Gauge Voltage Regulator (limiter) located?The car model is LS2
Jun 19, 2010 at 8:05 AM
SATURNTECH9
  • 30,869 POSTS
[quote:e2ed29a231="XUYENDO1"]Air Conditioning problem
2000 Saturn SL2 6 cyl Two Wheel Drive Automatic 150000 miles
How to replace the A/C compressor Clutch?. Also where is the fuel Gauge Voltage Regulator (limiter) located?The car model is LS2[/quote:e2ed29a231]
First of all which model do you have you say you have both a SL2 and a LS2 which one is it?Also a fuel gauge voltage regulator?What's wrong with your fuel gauge?
Jun 19, 2010 at 1:04 PM
