2000 Saturn SL2 fuses
KITTYKAT2001
Electrical problem
2000 Saturn SL2 4 cyl Front Wheel Drive Automatic
my door locks are jammed and are locking and unlocking non-stop. how can i fix it. or could you give me a diagram to locate which fuse to pull. I know where the fusses are but they are not labeled on the panel.
Mar 5, 2010 at 12:39 AM
SATURNTECH9
  • 30,869 POSTS
Most of the time it's a worn inside switch that doesn't return to the middle off postion the drivers door one compare that one to passenger side one.u can also unplug each switch one at a time and see if the locks stop if they do bad switch.they come out with a little pockect screwdriver.also check and make sure ur drivers side out side door lock is in the 12 o clock postion.u want the inside fuses the ones on the passenger side right in front of the center console.are u sure it doesn't tell what the fuses are on the fuse panel covering the fuses?ur looking for a 20 amp yellow fuse the locks one.there's only two 20 amps in there one is locks and the other is ur cig lighter fuse.
Mar 5, 2010 at 1:56 AM
