On my 2000 saturn sl2, my engine light was on for about two months. the comp. read that the EGR flow sensor was bad. I just recently replaced the EGR valve and right after i put it in the engine light went off, but five min. later it started flashing. The car still runs choppy and putters alot. I also replaced all the spark plugs and wires. It also makes noise from the exhaust. The car sat for about 6 months w/out driving it. Do you think i need a new catalytic converter? My cousin said that i probably have alot of old gas and carbon build up in my cat. What is your advise? thank you
Aug 6, 2010 at 8:08 AM
