Drive Cycle
FORGOTTENSIREN
I tried to get my Saturn Inspected yesterday, but it had been sitting in front of my parents house unused for 3 months and the battery was dead. I was informed after the battery was replaced that I would need to drive the car enough to reset the "drive-cycle" twice before anyone would even bother trying to inspect it. Can you please tell me what is required to reset the drive-cycle, as the inspection expires tomorrow, and I am incredibly nervous about driving a car with expired stickers. Thank you so much for your help.
Apr 30, 2010 at 2:20 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_19962000_obd2_drive_cycle015_1.jpg
first of all thank u so much for ur donation.i posted a drive cycle for u to try.after u complete ur drive cycle i would like u to drive ur car 50 miles after that to help reset ur monitors.let me know if it works.
Apr 30, 2010 at 6:11 AM
FORGOTTENSIREN
Thank you so much! I followed your instructions exactly, and ran through them twice. My car passed the inspection on the first try. I really appreciate your help. Thanks again!!
May 3, 2010 at 4:54 AM
SATURNTECH9
  • 30,869 POSTS
Glad to here that worked for u and ur back on the road all legal.that's what were here for and thanks again for ur donation.hope u use us again next time u have a question or a concern.also thank u for using 2carpros.
May 3, 2010 at 6:02 AM
THANKS!
SaturnTech9 I know this is an old post, but I wanted to thank you! Your instructions worked perfectly and my 2000 Saturn passed inspection. Thank you!
Apr 26, 2019 at 7:01 AM
  • 55,649 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Apr 29, 2019 at 6:03 AM
GLIATTALL
  • 11 POSTS
Hey Car Pros,
My 1998 Saturn SL2 drive cycle is taking forever to reset. I recently had a module replaced in the transmission. And the codes reset. I have driven the car almost 200 miles and its still not ready for inspection. I tried to follow a drive cycle sequence with no luck. I don't want to type out the whole sequence but it started with turning on the AC and Rear defrost. Is it possible that I'm not going into closed loop and would that cause the drive cycle to not reset? If so how can a check if the car goes into closed loop? Is there a special sequence to follow? What else should I look for. I have seen some posts that say it should only take 50 miles. One I read said something about driving 50 miles before turning that car off. Thanks for any suggestions.
Apr 29, 2019 at 6:04 AM (Merged)
  • 75,988 POSTS
OBD-II Driving Cycle
If you have a 96 or newer vehicle you have the OBD-II diagnostic system. This system is constantly monitoring the sensors and solenoids on the engine. If you have replaced the battery, disconnected the battery or cleared the codes after making a repair you will need to do what is called a "Driving Cycle". This will perform a diagnostic on all the systems the computer monitors. This cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start
In order to be classified as a cold start the engine coolant temperature must be below 50ºC (122ºF) and within 6ºC (11ºF) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle
The engine must be run for two and a half minutes with the air conditioner on maximum and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate
Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate
Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate
Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate
This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
GLIATTALL
  • 11 POSTS
This is the sequence I followed. I'm going to give it a couple more tries. Maybe I left the key on and heated up the O2 sensors or something. Is it possible that I'm not meeting the cold start criteria with engine temp and ambient air temp? Could a bad temp sensor or MAF sensor cause the ECM to recognize a cold start? I'll get back after I run the sequence a couple of times. Thanks.
SATURNTECH9
  • 30,869 POSTS
just wanted to add to this answer it's very common for the coolant temp sensor's to fail on those cars when in doubt change them there only 10.It's screwed into the cylinder right below where the upper hose goes onto the head.There is a black wire and a yellow wire going to it.Also inspect the connector if it's corroded i would change it also.The way i always reset the monitors after making a repair and clearing the code's on that car is to drive it over 50 mile's without turning the key off.also that car doesn't have a maf sensor it use's a map sensor.Please let us know how you make out.
GLIATTALL
  • 11 POSTS
It did turn out to be the coolant temp sensor. I replaced the temp sensor and followed the cold start procedure. Drove the car for about six miles without turning the key off and the drive cycle reset with not problems. Thanks for the help.
SATURNTECH9
  • 30,869 POSTS
Your welcome glad to hear you got the car fixed that's what we like to hear please tell all your friend's about us.
