2000 Saturn SL2 DOOR LOCKS
99,000 MILES • 4 CYL • FWD • AUTOMATIC
RACMARTIN
THE DOOR LOCKS KEEP FLUTTERING AND THE DOORS WILL NOT LOCK OR UNLOCK WHEN USING THE REMOTE; ALSO THE BATTERY IS BEING DRAINED AND ALMOST WILL NOT START DUE TO THIS PROBLEM. ANY ADVICE?
Jul 11, 2010 at 11:56 PM
SATURNTECH9
  • 30,868 POSTS
While the lock's are cycling unplug the door lock switches one at a time starting with the drivers side switch if the door lock's stop cycling when you unplug that switch then the switch is bad.Most likely your drivers side front switch is bad.
Jul 12, 2010 at 4:43 AM
