2000 Saturn SL2 Check Engine reports O2 Sensor
80,000 MILES • 4 CYL • FWD • AUTOMATIC
PATN03
Symptoms:
Muffler rattling all the way up to pass. floor board.
Engine flooded little while back and changed spark plugs.
Burns Oil 4 qt at 2500 miles (assuming different issue)
Checked:
Air filter
Changed:
Spark plugs
Gas Filter
I don't think it is gas filter change but can't recall if it happened before. I was thinking of checking the exhaust line. Might be as easy as changing the O2 sensors?
Mar 30, 2009 at 7:15 AM
BLACKOP555
  • 10,386 POSTS
what you mean muffler rattling all the way up to pass floor board?
what seems to be the problem?
do you have gas in your oil? i mean raw gas.
black exhaust smoke? blue exhaust smoke? rotten egg smell in exhaust?
Mar 30, 2009 at 1:23 PM
PATN03
The Check engine keeps firing off the O2 Sensor. The car runs pretty rough compared to 1 year ago. Gas seems to burn fine with pretty normal exhuast. By burn oil I mean draining oil doesn't yield much during oil change. 8 qt burn off during 5000 miles.
Yes you can feel the vibrations from the exhaust at the floor boards.
Sorry if previous message was confusing.
Mar 30, 2009 at 1:32 PM
BLACKOP555
  • 10,386 POSTS
so what would you like fixed.
ask me in laymans terms
Mar 30, 2009 at 2:37 PM
PATN03
Check Engine light giving off O2 sensor.
Mar 30, 2009 at 2:40 PM
BLACKOP555
  • 10,386 POSTS
ok. what code is it throwing?
need to know that way i can tel you what it is.
Mar 30, 2009 at 2:46 PM
