Electrical problem
2000 Saturn SL2 4 cyl Front Wheel Drive Automatic 1.9 miles
I have a 2000 Saturn SL2 and just removed the motor in order to replace the transmission. After putting everything back together we tried to start it and as soon as you turn the key the 30 amp ignition fuse under the hood blows. It appears everything is hooked up properly but still having problem. Does anyone have any ideas on what I should be looking for?
Sep 24, 2010 at 4:29 PM
