1999 Saturn SL2 transmission will not go into reverse
70,000 MILES • 4 CYL • FWD • AUTOMATIC
CALGENTMAN
The reverse gear stopped functioning immediately with no previous symptoms whatsoever w/transmission. I also noticed when car is in the reverse gear, if engine idle is extremely high enough the car does slightly begin to move backwards very very slowly but I can assure you that does not happen on a regular basis.
G.Gonzalez
Sep 29, 2010 at 11:21 PM
SATURNTECH9
  • 30,869 POSTS
Do you have any code's let's start there.
Sep 30, 2010 at 5:27 AM
