Hi Guys,
thanks for the help...
I have a speedometer/transmission problem, driving along, the speedo will drop to zero, and sometimes the car just runs on as normal, then the speedo will bounce back to the current speed. Other times the car will act like I have engaged the clutch (this is an auto transmission) and will rev up. then will eventually engage... then it happens again... I havent been stranded yet, but close. I have replaced the VSS, but no change in behavior. Thanks for the help in advance...
Jun 30, 2010 at 4:53 AM
