1999 Saturn SL2 ODD!! steering pull
259,000 MILES • 4 CYL • FWD • AUTOMATIC
BUCKHORNTECHS
99 Saturn sl2 and when you are driving it pulls to the right but not all the time. Had Ball Joints and tie rods done last year. Had the brakes changed issue got worse. New tires still not good. what i have notices is the steering wheel is in a 1 oclock position and was thinking now that all the other stuff was done it needed a front end alighnment. But the car tracks perfect before and after the pull.
Ok so the steering wheel is in the 1 oclock position you get the pull and it goes to the right you adjust and now the steering wheel is in the 12 oclock position. and tracks perfectly strait till you get the pull again.
Jan 30, 2010 at 11:41 PM
CHANN02
i've had the same thing happen to me as well i'm driving down the road then it just pulls right. almost took me off the road once i'm thinking it's my power steering pump because now it went bad and have no power steering at all very hard to drive without one, yours may be going bad. before mine went bad my wheel was in line but now it's at a weird angle then it should be. just thought i'd throw that in there maybe it will help.
Feb 2, 2010 at 2:24 PM
