1999 Saturn SL2 fuel cut off switch
200,106 MILES • 4 CYL • 2WD • AUTOMATIC
MARGARET MCAFEE
after being rear ended car was put in park and ignition turned off. Now car will not start.
Sep 7, 2009 at 7:31 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sep 7, 2009 at 7:47 AM
