1999 Saturn SL2 EGR/Secondary air intake Malfunction
135,000 MILES • 4 CYL • FWD • AUTOMATIC
FORTRUTHIUS
My engine light came on so I took it in and the diagnostic machine said "check EGR valve". So I spent $118 dollars on a new valve and had my mechanic put it in for me. My engine light is still on so I took it back and had the machine hooked up again and they said that the EGR valve popped up again as well as a secondary air intake malfunction....What is that? And What do I need to fix it? Where is it located in the engine? I'm getting rather frusterated and would rather not buy parts that I don't need and waste money. Thanks!
Apr 26, 2010 at 3:43 AM
SATURNTECH9
  • 30,869 POSTS
Could u please give me the code numbers u have so I can guide u in the right direction.let me know.
Apr 26, 2010 at 5:33 AM
FORTRUTHIUS
which codes would those be? the ones the diagnostic machine brings up?
Apr 27, 2010 at 2:08 AM
SATURNTECH9
  • 30,869 POSTS
[quote:53e74da9f3="fortruthius"]which codes would those be? the ones the diagnostic machine brings up?[/quote:53e74da9f3]
here's the problem i dont know which codes those would be.for egr codes u have p0401,p0404,p0405,and p1404 a few choices there u could even have more then one egr code.why dont u do this go have ur codes read again and write down all the code numbers for me.this isnt going to be a simple i know what it is i need the codes so i can lead u in the right direction and u will have do some testing.do u have a multimeter?iam not trying to be hard on u just trying to get u to understand why iam asking for the code numbers.iam here to help so please help me help u.let me know what u find.
Apr 27, 2010 at 4:34 AM
