My car is getting 12 mpg both highway and city average. I don't hot rod it, and i warm it up in the winter before i bring it out. This mileage is consistent for both the winter and summer. I calculate my mileage by miles driven/gallons used.
I have no clue what is wrong. I brought it to the GM dealer and they said the car runs perfect.
Here is a list of everything i replaced:
Battery
Air Filter
EGR Valve
PCV Valve
NGK Plugs and Wires
Control Module
Starter
WIX #33731 Fuel Filter/Regulator
ECTS and Connector
AIT Sensor and Connector
MAP Sensor
Front Manifold Oxygen Sensor, OEM
Thermostat
Valve Cover Gasket
Cleaned the Throttle Body
Battery
Air Filter
EGR Valve
PCV Valve
NGK Plugs and Wires
Control Module
Starter
ECTS and Connector
MAP Sensor
Thermostat
Valve Cover Gasket
Feb 3, 2010 at 12:59 AM
