1998 Saturn SL2 starter or ignition
143,960 MILES • 4 CYL • 2WD • AUTOMATIC
MANIACMASS
I have problems starting car.usually turns overwhen car is cool.I usually have to play with igniyion switch to get to start unless car is cool.can you tell me what the problem may be.replaced ignition switch.That did not work.
Jul 15, 2010 at 10:15 AM
  • 75,988 POSTS
Try shorting out the starter motor solenoid if it will crank the engine over if not test the starter relay, park and neutral position switch
Jul 15, 2010 at 10:23 AM
