1998 Saturn SL2 power windows
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAPASO
all windows stop working
Jul 6, 2010 at 12:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse and relay for power window circuit
Jul 6, 2010 at 2:20 PM
PAPASO
the relay is good and I can't find a fuse in the engine or the cabin for windows. Can u tell me the easiest way to raise the windows for now. do I have to disconnect the motors to raise them?
Jul 6, 2010 at 10:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the fuse #1 (green, 30 amp) in the underhood fuse block, fuse may be labeled PWR CONVCE
you would have to remove door panel and disconnect the motor and regulator assembly from the window glass before manually lifting glass up.
Jul 7, 2010 at 11:03 AM
