1998 Saturn SL2 leaking fluid
1998 SATURN SL2
26,900 MILES • 4 CYL • FWD • AUTOMATIC
JOEYSCH123
my transmission is leaking fluid. it started only when i changed the oil and had to use a screw driver to remove the oil filter because Walmart put it on to tight. i banged it to losen it up and after all that now I have a transmission fluid leak in the front of my car. Is there a hose near the front? if so where is it...that could have a hole in it....it leaks a steady stream.
Sep 19, 2010 at 4:07 AM
SATURNTECH9
  • 30,869 POSTS
So did you change the oil filter or the transmission filter because the oil filter is no where near the transmission to cause a leak there on the transmission.
Sep 19, 2010 at 4:36 AM
