1998 Saturn SL2 Leaking Coolant everywhere
200,000 MILES • 4 CYL • AWD • AUTOMATIC
SAVAGEJILL
I am leaking coolant out from under the right side of the car. It seems to drain completely with in a day or so. Could it be a hose is loose or something? Or does it sound like I have a whole somewhere? I am not car savvy in any way :( Any advice would be most helpful.
Feb 8, 2010 at 8:57 AM
SATURNTECH9
  • 30,869 POSTS
I would fill the car up with water and start the car let it idle and look for water comming from ur water pump that's right below ur a/c compressor.u could also see if ur water pump pulley is loose it's right below ur a/c compressor the thing with the little hoses going to it with it not running and the engine cool.the water pumps when they leak bad they get loose.let me know what u find.
Feb 8, 2010 at 11:16 AM
