1998 Saturn SL2 ignition
133,000 MILES • 4 CYL • FWD • AUTOMATIC
JBLACK31166
i need to change tne ignition or the lock cylinder for my car...how?
Jan 25, 2010 at 7:27 AM
  • 75,988 POSTS
Ignition Lock Cylinder - Removal REMOVAL 1.Disable the SIR system. (Refer to Disabling the SIR System in Diagrams/Diagnostic Aids/General Troubleshooting Procedures/The SIR System. ) See: Diagrams\Diagnostic Aids Ignition Switch: Removal
https://images.2carpros.com/forum/automotive_pictures/12900_isi1_1.gif
2.Remove two screws holding Data Link Connector (DLC ) to filler panels. 3.Remove the five steering column filler panel screws.
https://images.2carpros.com/forum/automotive_pictures/12900_isi2_1.gif
4.Remove hood release cable from lever by releasing cable housing, then rotating cable downward to cutout. 5.Remove steering column filler panel. Ignition Switch: Removal
https://images.2carpros.com/forum/automotive_pictures/12900_isi3_1.gif
6.Remove two upper-to-lower steering column shroud screws and three lower steering column shroud-to-steering column screws. 7.Remove upper steering column shroud. 8.Insert ignition key into ignition lock cylinder and rotate ignition key to ACC position. Ignition Switch: Removal
https://images.2carpros.com/forum/automotive_pictures/12900_isi4_1.gif
9.Depress the square locking button on the top of the ignition lock cylinder module and slide ignition lock cylinder assembly from ignition lock cylinder. Ignition Lock Cylinder - Installation INSTALLATION 1.Position new ignition and start switch (P/N 21024682) to ignition module assembly and install two screws and tighten. Torque: 2 - 3 Nm (18 - 27 in.lbs.) 2.Connect electrical connector to ignition and start switch. Ignition Switch: Installation
https://images.2carpros.com/forum/automotive_pictures/12900_isr1_1.gif
3.Position upper and lower steering column shrouds to steering column and install two upper-to-lower steering column shroud screws and three lower steering column shroud-to-steering column screws. 4.Install ignition lock cylinder into ignition module.
https://images.2carpros.com/forum/automotive_pictures/12900_isr2_1.gif
5.Route hood release cable through I/P, then install hood release cable to lever. Ignition Switch: Installation
https://images.2carpros.com/forum/automotive_pictures/12900_isr3_1.gif
6.Install steering column filler panel and Data Link Connector (DLC ). 7.Install and torque five screws. Torque: 2.2 Nm (20 in.lbs.) 8.Turn ignition switch to LOCK position and remove key. 9.Enable the SIR system. (Refer to Enabling the SIR System in Diagrams/Diagnostic Aids/General Troubleshooting Procedures/The SIR System. ) See: Diagrams\Diagnostic Aids
Jan 25, 2010 at 4:39 PM
