1998 Saturn SL2 iganation
1998 SATURN SL2
19,800 MILES • 4 CYL • FWD • AUTOMATIC
DCTDBR
was wanting to know how to fix my igatnation since it broke. Do I need to pull the steering wheeel
Aug 15, 2010 at 5:06 PM
SATURNTECH9
  • 30,869 POSTS
Do you mean your ignition cylinder?If so whats wrong with it?The more details the better?
Aug 15, 2010 at 6:21 PM
DCTDBR
It is the cylinder. it had a crack in it. It has broke some of it out. trying to get the rest out to put a new on in
Aug 24, 2010 at 6:16 AM
SATURNTECH9
  • 30,869 POSTS
If you can turn it to the acc position you can just slide it out.You just have to remove the upper steering shroud turn the cylinder to the acc position and there is a button you push and the cylinder slide's out.
Aug 24, 2010 at 6:29 AM
DCTDBR
I have tried to do that but it will not slide out. It has been broke and not much left in the cylinder.
Aug 24, 2010 at 3:40 PM
SATURNTECH9
  • 30,869 POSTS
If you can't you get the ignition cylinder out you will have to replace the ignition cylinder and the housing.You will have to remove the steering wheel air bag coil and multifunction switch.
Aug 25, 2010 at 6:24 AM
