1998 Saturn SL2 Headlights
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIM3475
Suddenly the "driving" or "safety" lights of my 98 Saturn (inner two lamps) stay On even when the engine is Off. Can't find relay or fuse specific to this function. All other light & signal functions OK. Is this a problem with contacts or wiring behind the ignition switch?
Feb 27, 2010 at 11:32 AM
SATURNTECH9
  • 30,868 POSTS
if u private message me ur email adress ill email u a wire diagram for ur lights it wont post on here for me.ur relay for the day time running lights that are staying on is in ur underhood fuse box its a little grey one labeled drl try unplugging it then plugging it back in see if u can feel and hear it click when ur doing that.if it doent click then that relay probably has a stuck contact.let me know what u find.
Feb 28, 2010 at 5:19 AM
